08-03-2006 04:06 PM
08-03-2006 04:13 PM
08-03-2006 04:30 PM - edited 08-03-2006 04:30 PM
Either array is simple. You first need to select waveform type from Convert From Dynamic Data. You can then use the Get Wavefrom Components to get the dt. Creating an array of times or increment by one array is just a matter of a for loop.
Message Edited by Dennis Knutson on 08-03-2006 03:31 PM
08-03-2006 04:38 PM - edited 08-03-2006 04:38 PM
Message Edited by jasonhill on 08-03-2006 04:39 PM
08-03-2006 04:51 PM - edited 08-03-2006 04:51 PM
Message Edited by Lammers on 08-03-2006 04:54 PM
08-03-2006 04:53 PM
08-03-2006 05:05 PM
08-03-2006 09:27 PM
04-11-2014 09:19 AM
Gr8 stuff :-). Worked for me.
05-12-2015 03:19 AM
Hey !
I am aware I arrive after the battle, but I have a small question going towards this direction !
I had the same issue as op, and solved it pretty much the same way as you ( For loop picking dt Y times bla bla bla).
Now I am in trouble for something basic ...
On one side I have the mean calculated from one channel of Data of my DAQ, and the other side this time array builded.
I just want to plot the mean VS this time extracted, and I can not achieve that ...
I tried to build another waveform from it, or concatenate it ... No way to solve that issue ...
Do you guys have an idea ?
PS : in other words, from my DAQ I get 2 channels of Data. I made the soustraction of one from the other, generated the mean of the result either from Mean.vi or Statistics->Mean vi and try to plot this VS the time data extracted exactly the way you guys explainned here
Thanks !
