09-24-2014 09:35 AM
Bo does know. Register the serial number, log in as the user associated with the serial number and you can have access to ALL LabVIEW versions up to the version that the serial number is registered for. The links will only be available while that SSP is current, so if you are thinking of letting it expire, download all the versions you'll ever think you'll need. 😉
I think an expired SSP only hides the downloads. If you have other means of access - say a CD or something - you can still install and use the versions your serial number is good for.
09-24-2014 12:29 PM
Well with the links you posted I have received and installed the software. We purchased a bunch of medical class stuff from another company and they told me we have purchased 2011 SP1 with our program. None of the codes have worked, but they are working on it. I think I have everything I should now. Thank you for answering so quickly. I will just have to wait on the correct codes now.
09-24-2014 12:40 PM
Do you want me to take a look at your codes and see what versions of the software they are meant for?
