06-17-2013 05:28 PM
06-18-2013 08:58 AM
The error message says that the column name you are using is incorrect. Make sure that the column name you are trying to access and the name of the column in the database are the same.
I can't look at your code ringht now, but another recommendation I would make is to not use the DCT. It is an unnecessary complication (and cost!). There is a free alternative available.
Mike...
