05-15-2017 02:06 PM
Hello
Tell me plz, how to fix errors
In the LV 7.0 the program is opened normally, but in the LV 2012 have many errors
05-15-2017 02:13 PM
@Morner wrote:
Hello
In the LV 7.0 the program is opened normally, but in the LV 2012 have many errorsThanks
Well... open it in LV 7.0 then! Seriously, though - what are the errors?
05-15-2017 02:37 PM
Errors only in the LV 2012
05-15-2017 02:45 PM - edited 05-15-2017 02:48 PM
You have a value property node that exists in one image, and is missing in the other. just to the right of a False case structure, and a bit to the left of the Error List dialog box.
Somehow that got deleted in the one version.
05-15-2017 02:46 PM - edited 05-15-2017 02:47 PM
Well, you might as well start from scratch and rewrite it using a proper programing architecture, not one big loop with a bunch of code fragments and possible race conditions.
05-15-2017 02:52 PM
In LV 8.2 or thereabouts NI rewrote the charts and graphs and in the process we lost the ability to access the cursor legend by right-click create ref >>> Property node.
There is a snow ball's chance in HE@# that if that code is updated to LV 8.2 there may have been migration code.
Otherwise will require a rewrite to work with modern LV.
Ben
05-15-2017 02:52 PM - edited 05-15-2017 02:54 PM
I guess that it's because in LV2012 property of control/or control type at all does not exist - thus property node for value of some control/indicator is just dissapeared. I don't have LV 7, so I can't go so deep, but I guess that you could check it by yourself also (I've highlighted that place).
Sincerely, kosist90
Check out new features and changes in LabVIEW 2017!
Upd: I was writing my answer too long 😃
05-15-2017 02:54 PM - edited 05-15-2017 02:58 PM
Sincerely, kosist90
Yes the old graphs got replaced and the access to the cursor legend changed drastically.
I have always thought NI did not think any of ever found that approach. WRONG!
Ben
