12-05-2013 12:45 PM
I found this solution, works like a charm!
https://decibel.ni.com/content/docs/DOC-31864
I'm now busy with the dehoughing of the image can I contact you if needed?
Sincerely yours
12-05-2013 12:57 PM
I'd rather like if you posted another thread in the forum.
If I knew an answear and had time to write a post, I probably will respond!
12-05-2013 01:47 PM
Okay, thanks for the help! 🙂
03-05-2014 03:12 AM
the picture is so big,i can't see it clearly. Would you please show me a smaller one? thank you.
03-05-2014 03:19 AM
This thread has several pictures, so you should be more precise.
If it is too big to see, wouldn't making it smaller make it even harder to see? Please explain your logic.
(If you are talking about this snippet, you can drag the image to your block diagram and it will turn into functional code. You can also open it in a new tab (right-click in browser) and then zoon to full resolution)
