07-02-2015 02:42 PM
I can use all the helps I can get.
any suggestion?
07-02-2015 03:59 PM
I would also consider putting something in each test fixture which the program can read to verify that the correct fixture is being used. This can prevent (or at least detect) user errors which could result in invalid meaurements. Without knowing more about your system I cannot provide specific suggestions.
Lynn
07-02-2015 05:15 PM - edited 07-02-2015 05:17 PM
Hi Lynn,
pretty simple jig setup; mechanical fixtures that only hold the vacuum trim capacitors (different sizes) and then I connect the LCR meter clips to the caps, adjust them to values within specs and read the numbers off of the LCR meter.
capacitors also have bard codes that I scan to read the serial numbers.
nothing more, nothing less.
07-02-2015 08:03 PM
07-03-2015 08:07 AM
Dennis... your suggestion of using Teststand did not hep at all. it is an overkill and I can't take that route.
07-03-2015 08:33 AM
