01-16-2011 03:53 PM
as the attachment , the blinkblink.vi is the main function i want to do .
how do i connect using the TCP/IP ?using the testserver.vi and the testclient.vi
need help. any expert here?
01-16-2011 05:51 PM
no people knows how to do it ?
01-16-2011 06:02 PM
Be patient. It's Sunday, there are fewer people on the forums.
Have you looked at the TCP/IP client and server examples in the Example Finder?
01-16-2011 06:50 PM
define "do"!
Do you want to send the new LED state whenever the two booleans change? What is the server supposed to do with the data?
(Your blinker code makes little sense, for example [i] is always less than 3 so at least one operation is meaningless. Also, the VI consumes all CPU resources when the switch is off. It is often easier if you make a clean diagram layout, not with wires going in all directions or often nowhere. Have you done any tutorials or classes?)
