10-29-2015 04:11 PM
Hi! I am creating databases of some products but also need to print to PDF417barcode format some important features. I'm not sure if it's possible and if it is, how to do it. Thanks in advance, really need help how to start with this (only the barcodePDF417 process)
10-30-2015 03:09 PM
I have used Morovia PDF417 Fontware (not free). Installing it loads the PDF 417 font into the OS (I was using Windows).
It also comes with a dll that you can make ActiveX calls to in LabVIEW to encode string data into a LabVIEW string indicator that is configured for the PDF417 font style.
Took about 30 minutes to generate/prin/test my first barcode witning LabVIEW once I installed the fontware and started playing around with the dll.
-AK2DM
10-30-2015 05:48 PM
Thank you for giving me a hand with this. I will think over it and try to do what you mentioned.
