06-10-2014 06:29 AM
Actually i'm transiting my code from NI-DAQ to DAQmx almost everything working fine with new code in DAQmx.
But i saw an option in AO write that one of its input is a boolean(Allow Regeneration). Now i transitted all my code to DAQmx i need allow regenration boolen option in daqmx so that i can trigger from a subvi to alloow generation to DAQmx write
I'm attaching both the VI's NI-DAQ and DAQmx for reference.Please have look and help me with a solution as early as possible.
06-19-2014 12:24 PM
Hi abhishek.d,
You can use a Property Node using the Task as the reference and select the property "Regeneration Mode"
Regards.
06-19-2014 02:01 PM
What's wrong with the solution you got in your other thread?
http://forums.ni.com/t5/LabVIEW/Regeneration-based-on-Boolean-Condition/m-p/2889288
06-19-2014 02:48 PM
Nothing wrong with ur solution crossrulzz it absolutely helped me a lot and the iisue had been resolved.. This was an earlier thread which is opened by me since i didnt get any response on this thread, by mistake i opened a new thread on the same question and on the same day u solved that issue..
Sorry for multiple threads..
06-19-2014 06:25 PM
Ok, I didn't notice the original post date. Well, as long as you have your issue taken care of, that's all that matters.
