03-25-2015 05:04 PM
I'm new to LabView . I am doing the acoustic test using Sound and Vibration Assistant. However, I do not know how to stay at one frequency for a while when sweeping the frequency.
I read the examples and instruments of sweep step, however, I am not clear how to make a number of cycles for each frequency constant, for example, 200 cycles.
I‘m so confused and I need your help. Thank you!
03-26-2015 08:39 AM
Is anyone familiar with Sound and Vibration Assistant? I really need your help!
03-26-2015 05:57 PM
Hey,
Can you give us some more information about how you are setting up your test? Also, you are using the Sound and Vibration Assisstant in Signal Express, not the LabVIEW environment, right?
03-26-2015 07:20 PM
Hi MegaWatts,
Thank you so much for your reply.
Yes, I am using the Sound and Vibration Assisstant. (In fact, I am not quite clear about the relationship between Sound and Vibration Assistant and LabView). Maybe I should remove my post to Signal Express board?
As for the frequency sweep test, I want to the Sound and Vibration Assistant sent signal from 1K hz to 10k hz with an increment of 500hz. I also hope there will be 200 cycles at one frequency in order to quite steady result. In order ro do that, I add a Sweep step in the project, however, I don't know how I can make a number of cycles for each frequency.
Thank you,
Yue
03-26-2015 07:30 PM
More information:
I want to do frequency sweep test using Sound and Vibration Assistant. I added the sweep step and chose sin wave frequency as the parameters. I selected frequency from 1K hz to 10k hz with an increment of 500hz.
However, I do not know how to stay at one frequency for a while when sweeping the frequency. I hope there will be 200 cycles ( or 5 minutes) at one frequency in order to get steady result.
03-30-2015 10:41 AM
cDAQ-9174
03-30-2015 11:35 AM
03-31-2015 12:52 PM
I'm sorry. The administrator can delete this post.
Just one more questions, is there still anything wrong with my description? In other words, why nobody give any answer?
Lena
