11-07-2015 08:55 AM
Hi there,
I have been trying to make a program which outputs a number based on the state of my motor.
The way I want to do this is as following:
If the motor turns one way, I want the number to increase by 1 everytime the gear of the motor presses a button
If the motor turns the other way, I want the same number to decrease by 1 everytime the gear of the motor presses a button.
The problem I have is that I cannot find a way to program it so that labview only responds 1x, right now when the button is being pressed it continually keeps counting.
Is there an option somewhere to only execute the if loop when a state changes? I have tried with event structures but have not been succesfull.
The way I programmed it now seems promising but for some reason the output of my formula node is not a natural number like the inputs, even though i only use the increment function
Here is a really short representation of my programme in pseudocode:
If Motor=10 and Stepcounter changes from 0 to 1:
increment number by 1
If Motor=01 and Stepcounter changes from 0 to 1:
decrement number by 1
Thank you for your time and help
Bram
11-07-2015 09:28 AM - edited 11-07-2015 09:40 AM
I would suggest to start with some LabVIEW tutorials.
11-07-2015 09:43 AM
11-07-2015 10:00 AM
The arrays shows 8 elements because the machine that we are making uses 4 motors, now we connect them to the pc via a DAQ and this gives the information to the motors in the form of an array, the first 2 elements of the array would signify the motor 1, the 3 and 4th would be the 2nd motor and so on. The motor can never be 11, because this would be a state where the voltage would be high on both poles. If the motor is 00 it means the motor is receiving no power and thus is off.
About the floating point number as output of the formula node, I do not know why LabView puts a orange line there and not a blue one.
11-07-2015 12:54 PM - edited 11-07-2015 12:58 PM
If you are trying to learn LabVIEW, use LabVIEW and forget about Matlab. The logic that you describe in the Formula Node can easily be rendered as LabVIEW code, as illustrated in the Snippet below (drag this onto a LabVIEW 2015 Block Diagram and it will become executable LabVIEW code). Note that if you start with a Boolean Plus State, it makes no sense to convert it to a numeric PlusState (0, 1) and then ask "If PlusState == 1" -- much simpler to ask "If Plus State = True". Also, you should learn about While Loops, Shift Registers, and how a Shift Register can act as a "memory element" to keep track of Position. [The code on the top is taken from your example, the code on the bottom is a non-Formula way of doing this -- the "else if" clause case is illustrated here].
11-08-2015 10:18 AM - edited 11-08-2015 10:22 AM
11-08-2015 02:13 PM
@GerdW wrote:
(Nearly) the same without case structure(s) and loops:
(To get the very same result replace the XOR by an OR…)
Code is typically easier to read if you would replace the XOR with a "Not Equal". Less nerfy. :D. You should also initialzie the shift regsiter with an integer to make that glaring orange go away. 😄
Still, you and Bob are solving a different problem. Where is the array input? The original problem had an array with two elements (givind direction) plus another boolean (from an encoder).
11-08-2015 02:23 PM
So 00 IS a valid state, e.g. if a fuse is blown somewhere. That would be very important to detect.
Also 11 cold happen if a moron wired things up. 😄
Code should be as smart as possible to handle everything. Don't sweep unexpected states under the rug but proactively handle them, even if their probability is near zero. Murphy's law applies in engineering more than anywhere else! Both of these states should be detected and throw an exception to notify the operator accordingly.
There are four valid states:
11-09-2015 10:31 AM - edited 11-09-2015 10:32 AM
Hi Christian,
I didn't open the VI, I just looked at Bob's snippet…
I had a lot of boolean logic stuff while apprenticeship (using pneumatic valves :D).
So whenever there is a problem involving boolean logic I think about AND/OR/XOR functions (or LabVIEW's CompoundArithmetic). Using (Un)Equal looks wrong in my eyes…
