NIOPCserve unable to load driver DLL D:\Program Files (x86)\National Instruments\Shared\NI OPC Servers\V5
There is a error in my OPC servers2013,when  it is started. NIOPCserve unable to load driver DLL  D:\Program Files (x86)\National Instruments\Shared\NI OPC Servers\V5.I dont know how to solve it.
(3,089 Views)
This is strange.  I presume this is LabVIEW 2013 installed on a Windows PC, right?  [You don't give us much information].  I'll note that I've never seen a Windows system where the System Device wasn't C:\, and where Program Files (x86) wasn't on the System Device.  Can you confirm this extremely unusual System Configuration?
(3,066 Views)
Yes. Lv2013 is installed on my PC .The sofrwares are all installed in D:\ on my PC including the OPCservers 2013. what other information do you need? thank you!
(3,058 Views)
I still suspect the non-standard location for Program Files is causing this.  Please try the following, which I've pasted as a LabVIEW 2016 Snippet, but have labelled so you should be able to create (most of) it yourself:
The key to this routine is the sub-Palette "File Constants" on the File I/O Palette.  If it includes the System Directory function, then code the top loop to return the 14 Named Paths (and their names).  When you run this, look to ensure that all of the Paths make sense on your system, specifically that none of them use C:\Program Files (x86).  On my system, the C:\ drive is definitely represented ...
(3,046 Views)
