NI9870 to control Agilent E3647A
I'm trying to control a Power supply E3647A using cRIO 9074 and NI 9870 in FPGA mode.
When I send the SCPI commands like APPLY, SYSTEM:REMOTE, INST:NSEL 1|2, OUTPUT ON|OFF, *RST, *TST?, the Power supply executes them (I can see this in power display). But when I use any query command like *IDN, APPLY? I've read anything.
I've tryed to use the E364xA drive but doesn't work, i've changed the power supply to another one and happens the same.
I need to read the query commands. some body could help me.
(4,392 Views)
First Try to do the same in Hyper termainal and Make sure you are getting reply.
(4,367 Views)
I've tryed this and i've got the same problem. I can write the commands and power supply execute them but I can not read the strings from equipment (if the power is writing anything).
any idea?
(4,342 Views)
Are you sure about the command you are using to read strings from the equipment is true?
(4,338 Views)
Sorry typho error....
Are you sure about the command that you are using to read strings from the equipment is correct?
(4,335 Views)
Yes, SCPI basic command *IDN?\n
It must write the <model number>,<serial number>,<software revision>.
I changed the equipment for another E3647A, one E3642A and E3649A and I do not read anything. I would like to know if someone achieve to receive this string via RS232.
I'm using a code that is in "find example" of Labview. I did some modification to adapt for my use.
In this program I read three ports simutaneous in differents baud rate. 2 ports I read bytes from another software and one I would like to control this power supply.
(4,314 Views)
Accepted by topic author jonesjol
Hi everybody,
I solved the problem.
The NI9870 doesn't use flow control DTR/DSR (only RTS/CTS) and the E3647A only use DTR/DSR.
It must be done programmable via FPGA I/O Property Node setting DTR State as asserted.
Thanks, PalanivelT, for try help me.
(4,198 Views)
