07-01-2015 03:40 PM
07-02-2015 04:34 AM
Hi aethon,
where are you trying to selesct the external source from the clock? Are you using LabVIEW? Can you post a screenshot of your code just to see what is going on?
Corrado
07-02-2015 09:10 AM
If you want to generate a clock with a digital output pin I think that you can find the example that you need in:
Help --> Find Example --> Hardware Input Output --> DAQmx --> Digital Output --> Digital - Continuous Output.vi
