06-03-2016 05:06 AM
In have just purchased a NI6211 M series USB device that has USB data streaming, but I can not figure out how to set the task up. I have found the property node for data transfer mechanism but I am getting the error message :
Possible reason(s):
Buffered operations cannot use a Data Transfer Mechanism of Programmed I/O for this device and Channel Type.
Non-buffered operations cannot use a Data Transfer Mechanism of Interrupts or DMA for this device and Channel Type.
Property: CI.DataXferMech
Corresponding Value: USB Bulk
Property: SampTimingType
Corresponding Value: On Demand
Channel Name: BulkCTR
Task Name: _unnamedTask<3>
Could you give me some pointers as to where to start with setting up this device as I have spent hours searching with no luck so far.
06-03-2016 05:40 AM
