NI cDAQ-9184 with Labview 2010
I have Labview 2010 and I'm trying to use the NI cDAQ-9184 with it, but the MAX doesn't recognize the device and the error -223805 appear. The chasis comes with the DAQmx-14.1 drivers, I install them and now the MAX recognize the device but in Labview the DAQ assistant is missing.
I try to uninstall the drivers and reinstall de old ones, but the MAX start to don't recognize de device again.
Anyone knows how I can get the cDAQ-9184 working under Labview 2010?
(2,773 Views)
Accepted by topic author Sara_
Hi Sara,
Trying to help you with your issue, I would do the following
If you are not working with any other device, uninstall the Daq-mx 14 or the one you have installed in MAX and install the Daq-mx 9.9.
- The cDAQ-9184 works with the DAQ-mx 9.6 and later:
NI cDAQ Chassis NI-DAQmx Software Support (table 1-1)
http://www.ni.com/pdf/manuals/372780h.pdf
- LabVIEW 2010 supports up to DAQ-mx 9.9 and earlier
NI-DAQmx and LabVIEW Compatibility
Http://www.ni.com/product-documentation/53326/en/
I hope it helps you solve your problem.
(2,663 Views)
Hi Cesan,
That works!!
I uninstalled the DAQmx 14 and reinstalled the 9.9 instead of my old DAQmx and my device now works fine.
Thank you very much!!
(2,646 Views)
