NI-XNET Error 7 at Open/Create/Replace file in Stream Open Logfile.vi
I am working with J1939 and specifically using the LabVIEW example J1939 Frame Input Stream.vi. I have edited the example in my own copy, and this time the NI-MAX gave error 7 at Open/Create/Replace file. Screen shot attached. How can I clear this error?
(2,624 Views)
Does the folders exists on your PC?
Do you run your vi on a PC? What is your hardware setup?
It is hard to help you when we do not have your vi to look at.
(2,586 Views)
Attached are the files that I used to run the program. I searched for the files in the error message and found two listed in the message.
Is it the right way to do it; Changing the path to where the NI-XNET is pointing at?
(2,565 Views)
So where is the files? I only see some images.
Where are you runing your code, on the PXI system or a PC ??
Where is the log file path?
(2,550 Views)
