03-26-2014 01:43 PM
I got a some proble with the fonction find a Circular Edge of LabView Vision. The problem is when the fonction found my circle he put a red circle, This is good ! but when I move the object for try to track the point, all the old red circle won't disaper.
After i while its pretty messy in my interface.
I got a image of the problem.
I want to know how to erase all the circle a each iteration.
Thank you
03-27-2014 09:58 AM
Hi PIOU123,
To clear the overlay use the IMAQ clear overlay VI. An example of this VI in use can be found by going to Help>>Find Examples and then navigating to Toolkits and Modules>>Vision>>Geometric Matching>>Geometric Matching.VI
04-01-2014 04:15 PM
Thank you for your advice
Piou123
