NI-Visa Freezing Application
I created an exe using labview 2011 to comunicate through a USB to dh485 adapter. The driver is from FTDI its the newest version.
I am running windows 7 64 bit on my laptop. I can run the exe on my laptop with the adapter plugged in and never have an isuue. I've install the exe on an acer veritron running windows 7 64 bit, and installed NI-Visa 5.4. I can run the exe and it opens the comm port, starts communicating, reads the correct information for a few minutes and then freezes on a Visa read instruction. The application stops, no further loop interations occur.
I've installed the development software on this pc to try and figure out the problem. I just dont understand why the code halts at a VISA read on this pc only. The exact same code is from on my laptop and it works fine.
Any suggestion?
(2,390 Views)
Check the USB Power management options  Is the OS is shuting down power to the USB port after a period of inactivity? (Default setting)  you can change that from windows device manager
"Should be" isn't "Is" -Jay
(2,388 Views)
I had already gone through all the USB Root Hubs under device manager and unchecked "Allow thw computer to turn off this device to save power"
(2,377 Views)
Hi Joe_John,
Have tou tried all the usb ports on the PC?  Typically, it is much better to use a port that's attached directly to the motherboard (in the back of the computer).  Also, are you using usb 2.0 or 3.0 ports?
Thanks!
Mason M
(2,348 Views)
