01-25-2008 10:44 AM
01-28-2008 06:32 PM
01-29-2008 09:35 AM
01-31-2008 03:47 PM
Hi AJL,
The evaluation version of NI OPC Servers is the same as the activated software. What are the names of the servers you were connected to and are currently trying to use? NI OPC Servers, which you recently purchased, appears as National Instruments.NIOPCServers. You may also see National Instruments.OPCDemo listed. Although expanding that shows "NI OPC Demo Server," it is not related to NI OPC Servers. OPC Demo Server ships with LabVIEW and is used with the DataSocket example programs. OPC Demo Server, unlike NI OPC Servers, can be used with LabVIEW 7.1.
Hopefully this helps clarify things a little.
02-01-2008 07:04 AM
02-05-2008 06:18 AM
Hi AJL,
NI OPC Servers are not compatible with Server Explorer. They will only accept client connections from LabVIEW 8.5.
03-11-2009 08:47 AM
I tried to connect to NI OPC server using Matlab OPC toolbox.When i click connect in OPC toolbox in Matlab I've got the following error when it tried to connect: Class is not licensed for use My question is about the compatibility between Matlab OPC toolbox and National Instruments.NIOPCServers Thanks, Stephen82 |
03-12-2009 10:42 AM
