NI-MAX doesn't show network devices
I have two piece of equipment (rate table and oven) which are using network connection. I used a router to connect the equipment and the PC. By using DHCP, I got the IP address for PC (192.168.1.2) and rate table (192.168.1.3) and oven (192.168.1.4). From the computer, I can also ping those two equipment.
In the router web page I can see these equipment shown in the attached devices tab.
When I open NI-MAX, unfolder the devices and Interfaces. I don't see any equipment shown under "network devices". I tried to creat a new VISA TCP/iP resources using the IP address. Still doesn't work.
BTW, I did reinstalled the NI-VISA 14. Still no fix.
Appreciate any kindly help.
David
(2,873 Views)
David
First, I wouldn't be using DHCP. We don't.
Second, if these two pieces of test equipment don't support LXI, why would you expect them to show up in NI-MAX?
(2,865 Views)
