NI License manager locks up
When checking the License server with NI License Manager, there appears to be no timeout built into this application, so if it cannot connect to the server for some reason, it justs sits there.............
Would it not be better if it had say a 30 second timeout so that it could report that it could not connect, rather than just sitting there?
(3,145 Views)
Dear Nigel,
I have not personaly experienced this but it is a timeout for this connection. Do you use a disconnected license you can go on and change the settings for this to avoid this lookup.
http://digital.ni.com/public.nsf/allkb/1EF6B40293D502B586256DFE00599210?OpenDocument
Best regards
/Lars
(3,068 Views)
I am using a Volume license server that is located in another continent, but within the corporate network.
If the connection cannot be made it just deems to wait forever and never times out.
(3,054 Views)
Dear Nigel,
Ok I see your point,  but unfortunately NI license daemon doesn't support the option to change this settings.
http://digital.ni.com/public.nsf/allkb/DCB86508B3C2512A862572D5005D750F?OpenDocument
In your case, do you get this issue often and in that case can we try to work towards a workaround.
Best regards
/Lars
(3,045 Views)
It just appears that there is no connection timeout facility built into the License manager.
So a simple solution would be to add one say of 15-20 seconds and report that the connection could not be established.
At least then it could close gracefully rather than having to Kill it as I have to do now.
I know it s not a major issue, just an annoying one.....
(3,040 Views)
Dear Nigel,
I see, I'm with you on this one.
I tried to find more information on why this timeout is set to be long as it is, but without luck. I believe though that the developers of the License manager have their reasons.
(3,016 Views)
