NI Home
Cart Cart | Help
You are here:
Reply
Member
JoeSavage
NI Installers & downloaders do not support proxy servers requiring authentication
Hello, I'm posting this on the LabVIEW forum since it applies to the LabVIEW installer and evaluation version downloader, but it also applies to other products that use the NI meta-installer framework and other products that use the NI downloader.
We are behind a corporate firewall which requires the use of a proxy for internet access.  In addition, the proxy requires authentication, which I believe is the complicating factor.
When running an NI installer, if we check the box that requests that the installer contact NI for new notifications, this will inevitably fail when trying to connect to the notification server.
Also when trying to use the NI downloader to download drivers or other products, the download always fails.
Most other software (e.g. Browsers, Dropbox, etc.) are able to use the proxy and allow entry of the username and password (either through a pop-up username/password dialog or configuration page).
This has generally not been a showstopper problem, but since it affects the NI installer framework it impacts many products and thus they would all benefit from a single bug fix.
Joe
Member
EricR
Re: NI Installers & downloaders do not support proxy servers requiring authentication
[ Edited ]
Hello Joe,
Thank you for posting to our forums.
We are aware of the proxy firewall issues.  The issue with the downloader will be fixed in the next week or two.  If there is a specific update you are trying to get, please let me know and I will be happy to make sure we create a new downloader for it.  In the meantime, you should be able to download the raw file without using the downloader.
The issue for the installer will be fixed in Q3 2011. In the meantime you can visit this website to see a list of all of the installer notifications along with a chart to determine if any of the notifications apply to your installation scenarios.
http://zone.ni.com/devzone/cda/tut/p/id/9098
Please let me know if there is anything else we can do to help you.
Member
EmbDev
we are currently running into the same problem:
After entering the serial number for licence activation the installer for Labview (Full Development) on Windows7 (started from a brand new installation DVD) soon fails with the notification that "an error occured at the server". Probably, the reason is that the installer does not make proper use of our enterprise proxy server, which requires authentication. The proxy is configured in Windows' network settings.
So we have two (expensive) licenses, which cannot be installed?
Can anybody give some advice how to proceed now?
Christian
Member
EmbDev
Well, the solution for the LabView base installation was to deactivate all requests for online registration and continue with the installation. When LabView is run for the first time, it offers other possibilities of product activation (e.g. using a proxy-aware browser).
Unfortunately, this option was mentioned neither by the installer nor by the  accompanying documents.
Christian
Member
Malanar
Same problem, here.
Trying to download Labview 2010 64 bits, got the downloader. It fails everytime, no option for proxy or login/password.
Where can i download the full exe file of Labview 2010 64 bits, only found the downloader.
Thanks.
Member
Sanjay_C.
Hi Malanar,
You can download a variety of software from the Services Resource Center after logging in using your ni.com login. In the Services Resource Center, the LabVIEW 2010 64-bit download can be found here.
Sanjay C.
Embedded Software Product Manager| National Instruments
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
