07-09-2015 04:31 PM
NI Measurement & Automation Explorer version 14.0.0f0.
USB instruments detected by Windows Device Manager, are not found by Measurement & Automation Explorer.
Solved! Go to Solution.
07-09-2015 04:35 PM
For MAX to see them, you may need the LabVIEW-compatible Driver. Can you tell us more about the device that MAX doesn't see? Like its name and identifying numbers?
BS
07-09-2015 04:40 PM
LabVIEW MAX does see them on other machines.
Also, they are simple USB / RS-232 interfaces using Prolific and FTDI.
07-09-2015 04:42 PM
Do those other machines have drivers by Prolific or FTDI?
BS
07-09-2015 04:44 PM
Yes to both.
07-09-2015 04:46 PM
Sigh. This is a slow process -- and does your machine also have these drivers?
BS
07-09-2015 04:47 PM
Yes, both machines have both drivers.
Both have current updates.
07-09-2015 04:51 PM
Sorry, that's a real puzzle! If you figure it out, please post the solution and enlighten us -- sounds like you did all the Right Things and it Should Work (Famous Last Words) ...
BS
07-09-2015 09:49 PM
07-10-2015 11:37 AM
Uninstalled all LabVIEW.
Installed LVRTE2014SP1 Run-Time Engine.
Tried running Stand alone executable (from Builder). No Luck.
Can I get MAX without Development Software?
