NI Cable
Hi Everyone,
I there a difference between the following two cables:
1. SHC68-68-RMIO
2. SHC68-68-EPM
If I have R-series DAQ device, is it possble to use the second cable instead of the first one? Any suggestion and advice will be highly appreciated. Thank you.
Kind Regards,
Opuk
(3,476 Views)
Hi Opuk,
why don't you call your local NI support? They should have an anwser to your question…
(3,433 Views)
Most likely there is. Not in the connectors itself but in the cable construction internally. Those cables are not simply 68 wires connecting the corresponding pins. They are rather build up with various cable combinations internally, such as twisted and/or shielded cables. The selection of which wires need to be twisted together or shielded is depending on the function of the individual signals. And that is why there are different cables for different devices, despite that the connectors are the same on both ends.
So as far as DC is concerned the cables are most likely the same, but as soon as you want to use them to send time variable signals (AC) over them they are anything but the same. It can make the difference between a properly working system and one which causes all kinds of interruptions and signal corruptions because of crosstalk and wires which are not impedance matched to the source and load.
Rolf Kalbermatter
My Blog
(3,415 Views)
Thank you so much for the insight Rolfk. I am very grateful for the information. GerdW, the last time I sent them and email they did not respond.
Kind Regards,
Opuk
(3,395 Views)
Hi Opuk,
I usually call them (by phone!) - and they answer immediatly…
(3,380 Views)
Helo GerdW,
I will do that. Thank you so much for the advise.
Kind Regards,
Opuk
(3,372 Views)
Kind Regards,
Opuk
Again,  What happened to the "Call Me Now!" buttons?
"Should be" isn't "Is" -Jay
(3,351 Views)
