03-21-2013 05:05 AM
I need to use a NI cRIO 9082RT chassis with cRIO modules.
I never use these technology before.
I would know how to realize my FPGA software development.
For example : I have cRIO 9205 & 9264 modules in my chassis.
Can I develop one software code which call I/O of both cRIO modules in one FPGA vi?
Can I develop one software code per cRIO module?
Funkry
03-22-2013 07:40 AM
Hello funkry,
By using the following document :
NI C Series Module Compatibility Chart
you can check if your module can be used in Scan Mode and/or FPGA Mode. For your 9205 and 9264 modules, there is no problem for calling I/O's modules in one FPGA VI.
What do you mean by "one software code per cRIO module"? If you want, you can split the code in two sub-VIs and calling them from a main VI. You can also read/write to your I/O with two separate VIs but if you wish to run two separate main VIs at the same time on the cRIO, this is not possible.
If you are interested in training courses regarding RT/FPGA/cRIO, don't hesitate to contact a sale representative from National Instruments.
Jérémy C.
NI France
03-22-2013 07:47 AM
Thanks for your answer and your reactivity.
I didn't know how a cRIO chassis work but now it's clear for me.
Funkry.
