NI 9401 Square wave generation
Hi all,
I'm a beginner with Compact Rio and Labview. I'm using cRio9022 and wanting to generate a duty cycle controllable PWM with NI9401 module. I have firstly set up a very simple VI with fixed duty cycle and frequency for the square wave. I aslo configure the NI 9401 ports to be output. But when I measure the output port od 9401, there is nothing there....Can someone help me out? Really appreciate your help.
(2,403 Views)
Hi ==8D==,
Here is a link which should get you started,
http://www.ni.com/white-paper/3254/en
From what I can see, your current code is not inside a while loop and you would need to configure the square wave simulator to operate outside of a SCTL if you had not done so.
DylanC
(2,384 Views)
