04-27-2016 02:03 PM - edited 04-27-2016 02:06 PM
Is there a way to programmically change the resolution of an analog out to a lower limit? The 9263 is +-10, 16bit. I'd like to alter this so I can decrease my voltage limits, thus getting a better resolution.
04-27-2016 02:07 PM - last edited on 04-04-2024 01:35 PM by Content Cleaner
Not according to the specs, it has only one range
https://www.ni.com/docs/en-US/bundle/ni-9263-specs/page/specs.html
04-27-2016 02:09 PM
Could I setup two channels? One with a hardware voltage divder and one without. I could then tell labview to use one channel at certain voltage levels?
04-27-2016 02:15 PM
Is there any Analog Out device that NI has that can output voltages from 10mV to 20V? The 9263 only has a 0.05V minimum
04-27-2016 05:26 PM - last edited on 04-04-2024 01:35 PM by Content Cleaner
Hi skinner,
Well, the NI9263 is capable to do so. With an accuracy of 14mV as stated in the specifications…
Really? Where does it say so?
Couldn't find that in the specs…
04-28-2016 09:11 AM
Yea, that was my mistake. The 9263 will work for my application.
