NI 9213 FPGA Node duplicate terminal
When I run the subVI for the NI 9213 Getting Started.lvproj, "NI 9213 Gettting Started (FPGA).VI, get a error statitng that the FPGA node has duplicated terminals. When I look at the terminals I don't see any duplicated ones... I can't seem to edit this VI also. What could be causing this error and how can I resolve it?
Jose
(2,765 Views)
OK,
I talked to an engineer and it seems that I had to separate the Auto Zero terminal from the rest. I opened a new node where only the Auto Zero was located and removed it from the original node. I was able to compile it untill I got a new error that says:
"You cannot run this VI because the target resource does not match the actual type of device.
Right-click on the FPGA target in the Project Explorer window and select Properties from the shortcut menu. Enter a Resource on the General page that matches the target type."
I went to the FPGA Target, but and I think that the default Chassis used is 910x. I'm using 9114,  I want to change this but I can't seem to be able.
Jose
(2,762 Views)
Accepted by topic author Jose_Perez
Hey Jose,
You should be able to remove the incorrect backplane from the project, and then add in your backplane under the cRIO controller. It is important that the backplane in the project actually matches up to your hardware as the FPGA chips are different across our backplanes.
Doug B
(2,749 Views)
Doug,
I managed to do this. Now my program is running. I'm still having trouble with some of the modules in the chassis though. I hope to get this working soon.
Jose
(2,737 Views)
