What version of the NI 845x driver are you using? To get support for
LabVIEW 8.2, you will need version 1.0.1, and you can find it
here.
If you already have that version installed, then you may not have
selected support for LabVIEW 8.2 when you installed, or you may have
installed the driver before you installed LabVIEW 8.2. In this case,
you will need to go into Add/Remove programs, click on National
Instruments Software, and click on change. Next select the entry for
NI-845x, and click on Modify. When the installer comes up, be sure to
select support for LabVIEW 8.2. Hope this helps.
Ebele O.
