04-18-2017 09:46 PM
I am new to LabVIEW and currently I want to use a waveform generator (5412) and a terminal block (TB-2708) on PXI to generate a signal and receive signal data, respectively. I looked some examples and found both of them need a series of blocks to define and set the waveform generator and the terminal block but I do not understand the meaning of each block and in each example, the programming flow looked different. Sometimes the flow includes one block which does not appear in the other example.
Does anyone know what are the programming flows for these two devices? Which example is the most representative one? Or, where can I find a document or video to teach me how to use these devices? Thanks for your help!
04-19-2017 07:32 AM
This appears to be a very old device -- the only information I could find on the Web talked about using Traditional DAQ to program it. I don't know what manuals or software you have available -- does this device (the NI 5412) show up in MAX? If your only tool is Traditional DAQ, and not DAQmx or one of the more modern Toolkits, you may (seriously) want to consider doing whatever you need to do with other hardware ...
04-19-2017 02:31 PM
Hi Bob,
NI 5412 is a 100 MS/s arbitrary waveform generator while NI TB-2708 is a DAQ. I think I can use LabVIEW to program both of them.
