NI-5122 Two Channel Simultaneous Acquisition
I'm looking at the NiScope EX Configured Acquistion VI, and i would like to modify it to gather from both channels simultaneously. How can i do that?
If I'm acquiring 1M samples at 1MHz, it will take one second... but i would like to have both channel data to be roughly taken in the same second.
thanks
aleks.
(2,324 Views)
Why don't you just put both channels in the Channels Names(s) control? The simulated example even shows this.
(2,315 Views)
Hi labuda,
To follow up with Dennis's comment, you can include multiple channels in the "Channel Name(s)" control on the front panel.  Just separate the channel numbers with a comma as demonstrated in the niScope EX Simulated Acquisition.vi example.
Andrew W
(2,295 Views)
