NI 488 error 8 error 7
Some possible errors that will be observed after a new install of the PXIe 1065 running on the network. The fix for our issue is listed below.
 Labview file permission error.
C:program files\PACS v3.2.20.4\PACS V3.2.22.3\PACS_config.ini
Error 8 occurred at open/create/replace/file in writer spreadsheet string. vi> write to spreadsheet file (DBL,V.) for file
Error 7 occurred at open file + vi open file
Possible reason(s) Labview file not found
NI 488 Non existent GPIB interface
The  issue was resolved and ran great after a little IT tweaking. After the install the permissions for the profile that we where using did not have the correct access associated with the admin group or being to run PACS as administrator. So before you reinstall be sure to check for this option.Cheers
Message 1 of 1
(2,199 Views)
