N9010a
Just wondering if anyone has used labview with the Agilent N9010a SA?
If so could someone tell me how to select under the WCDMA mode to measure EVM using the commands?
and also once this is selected to read the EVM RMS value?
I have connection and am controlling everything else, i just cant find how to connect to this measurement value.
Many thanks in advance!
Alex
(2,509 Views)
Hi Alex,
I noticed that no one's responded to your post.
Unfortunately, I don't have any experience with using Agilent products, but I was able to find the following manuals on their site that may or may not be helpful for you.
The first references the W-CMDA mode, and the second references the EVM value:
http://cp.literature.agilent.com/litweb/pdf/N9060-90029.pdf
http://cp.literature.agilent.com/litweb/pdf/N9020-90112.pdf
It seems that you've already taken care of the part I could assist with (connecting and general communication), but, if you have any questions about either of those topics, throw 'em out there!
Mike
(2,468 Views)
Accepted by topic author Detox92
Thanks you the help. Indirectly you pushed me in the right direction!
After looking at those manuals one of which i had and the other i didnt (Thanks!), I decided to see if i could find a programming guide to the particular mode (WCDMA) itself and hey presto!
application-notes.digchip.com/018/18-22360.pdf
Thanks again and I will be in touch regarding connections in the future, the VISA method is still baffling me!
Alex
(2,453 Views)
No problem. Happy to help! 🙂
Mike
(2,438 Views)
