06-27-2014 01:30 PM
I am looking for ideas on how to impliment the following:
I am redesigning a program that will take data from Labview and place this data into an comma-delimited text file on another file server. One of my many "mini-projects" is to take a square and make it into a N x N square. Think of a large square that has smaller squares inside of it. There are two pieces if information that need to be handled & displayed on the U on each square: The identification number info and the samples value from a external serial device. I am having issues displaying the N x N square. I'd like to make this dynamically if possible. I want to start small, like a 2x2 square.
Has someone done something like this and if so, where do I even start?
Eric
Solved! Go to Solution.
06-27-2014 01:37 PM - edited 06-27-2014 01:41 PM
I really didn't understand what you meant by N x N square. Do you mean to form N number of rows and columns with some value? Please explain
If possible can you show a picture of what you are looking for?
06-27-2014 01:42 PM
You got it. I need to hold two pieces of information within each row and column:
I want to display both pieces if information on the UI; like a grid.
06-27-2014 01:44 PM
Start with a 2-D array of a cluster that contains the controls for the values you want to display. Use the "Replace Array Susbset" to place your data. It won't work if you specify a location that is out of bounds, so you'll have to pre-define your array size, first. (This may seem tricky at first, but you shouldn't have any problems obtaining this if you just think about it a little bit.) You can resize the array control to display all your data with the array property node.
06-27-2014 01:44 PM
The below VI should get you an idea although I do not like how it's implimented. Is there a better way?
06-27-2014 03:21 PM
billko,
I've been successful manipulatuing the columns and rows in my test vi, but how do I go about writing data to the Array Cluster? The VI is in 2012.
Eric
06-27-2014 03:52 PM
@Eric1977 wrote:
billko,
Eric
You got the idea, but the control should be an indicator, since you want to display data. The input to that indicator will be your data. 🙂
06-27-2014 04:08 PM
Well, that's not necessarily true; at least for the string.
At times, my users will need to update the Mold ID string as molds get replaced and get saved back to a MS Access database to be used at a later date so I cannot use indicators as you suggested.
06-27-2014 04:59 PM
Sorry, I just assumed that this was for information only. In that case, you can keep it as a control, but do the original data popualtion with a local variable. I'm not sure of your skill level. Do you already have a plan for the rest of the stuff?
06-30-2014 07:17 AM
I do. I am just not sure of how to populate the data per the Replace Array Subset like you suggested. When I try to add data to the Array Cluster, it does not appear to add any data.
