12-29-2008 04:14 PM
I have a vi that takes two values and reads them into an array. It then uses a shift register to go back and get two more values. When the vi inserts these two new values into the array, it zeros the original two values, even though I am inserting them at the next two index values.
12-29-2008 04:44 PM - edited 12-29-2008 04:44 PM
12-30-2008 03:47 AM
Matthew,
Thanks for replying. Believe it or not, I finally solved it last night. I put the initializing sub vi inside a case structure to read the first two values instead of outside the for loop. The next pass throught the data used the next case structure with a 'insert array' and everything works fine. I can't believe it took me so long to solve this one, but it really feels great when you get it on your own.
Ron
12-30-2008 03:54 AM
