11-27-2014 09:52 AM
How can I read data from 8 analog input voltage channels using the DAQmx, specifying different sample frequency for each channel?
When I open DAQ assistant, I can choose only one sampling frequence for all the channel.
But for example, if I would like to use 8 signals on the same vi for different purposes, using different sampling frequency, how do I do it? Will I need to use 3 DAQ assistant one for each channel?
Solved! Go to Solution.
11-27-2014 10:01 AM
11-27-2014 10:04 AM
Thank you!
How can I decimate the individual signals?
11-27-2014 10:06 AM
