I have an application for a PDA that has several subvi's that are called to present different user interfaces. Each time a new subvi is loaded, it and all of the others are listed in the running program list. Ideally I would like to have only one item appearing in the running programs list regardless of the number of 'screens' running.
My work around is to use a tab control with the tabs extended beyond the viewable area of the screen. The software switches tabs depending on the operators menu selections, this ensures that a single application appears in the task manager.
