01-12-2015 02:18 AM
Hi all,
I'm trying to tabulate the data obtained from 2 analog pins. I've managed to do so by using multilist column. However, I do not know how to put the values on x-axis (time in seconds) into my table. Can anybody guide me?
Also, I've tried putting the table in a while loop to ensure that my data are plotted in the graph and tabulated in the table simultaneously but to no avail. The data is only tabulated after I stop the operation.
I'm unable to upload my file as it mentioned that file does not match its file type
Thank you in advance
Cheers,
Jamie
01-12-2015 03:53 AM
01-12-2015 04:11 AM
Hi sbarhe,
Below is the snapshot of my vi.
01-12-2015 08:00 AM
01-12-2015 08:26 AM
01-12-2015 09:09 PM
Hi all,
Thanks for all the responses. I deeply appreciate the help you guys have provided to me.
Back to my project, when I shift the "Multicolumn Listbox" ItemNames into the loop, I am unable to wire the "Build Array" to it. It says different dimensions. What should I do? I'm also unsure of where to put the shift register since my values comes from the output of "LINX Analog Read". It's actually my first time using LabVIEW.
Thank you
01-12-2015 09:25 PM
01-12-2015 09:51 PM - edited 01-12-2015 09:53 PM
Dennis_Knutson,
What do you mean by another Build Array? Did you take a look at the screenshot I've attached earlier? And why isn't my first Build Array output in array form instead it is in 1D array with 4 elements input into the Build Array function?
01-12-2015 10:02 PM
01-13-2015 02:03 AM
Hi Dennis_Knutson
I've managed to get what I've wanted. Thanks for your help!
Also many thanks to the others who helped me out. 🙂
Kudos to all
