07-25-2005 01:07 AM
HI,
So if you have so many labview machines then what is the problem,just make a copy of the code into different machines and run the test program.
vicky
07-25-2005 01:08 AM
07-25-2005 01:45 AM
Ok ,so what you do if you dont want to create a exe or application is just create a .lib file and save it in all the pc's and use it.by this you will have only one file to handle.
hope this solves your problem.
vicky
07-26-2005 02:05 AM
07-26-2005 02:10 AM
Use a probe to read the path which is passed to the config file vis.
I think you made it correctly, but you just append a filename without an extension. Is this correct? If you have a *.ini file you have to appen "EfficiencyTest.ini" to the build path function.
Thomas
07-26-2005 02:35 AM
07-26-2005 02:57 AM
As far as I know it is not possilbe to store any other files than *.vi, *.vit, *.ctl in a llb.
And what do you mean with "compile with the llb file"?
07-26-2005 03:31 AM
