12-07-2013 08:37 PM
Hi all
I can acquire one channel data and am trying multi channel data acquisition using PXI-6143.
And I made attached code.
But in this code, the signal in ch1 is acquired and in ch2 is not acquired. Why?
FrontPanel.pdf is the front panel of this code during operating.
AI1 and AI2 are input same signal 1Hz sine function.
I'm grad if you teach me the solution.
12-07-2013 09:18 PM
You don't mention it but you are certainly getting a resource reserved error. Search the forum for the message or code or simply fix it by using a single task with multiple channels.
12-07-2013 10:29 PM
Thank you for your comment.
What is reserved error?
That means errors are not indicated but occured?
12-07-2013 11:13 PM
12-07-2013 11:27 PM
I improved the code as attached file by referencing this and it came no errors.
12-07-2013 11:29 PM
12-07-2013 11:30 PM
The file is attached on my original post!
12-07-2013 11:34 PM
12-12-2013 05:59 AM
When the code was run without a function generator, no error was occured.
But when the code was run with a function generator, an error was occured.
Thank you and I will try to resolve this problem!
