04-03-2017 10:12 PM
Hii Friends,
Can anyone help me to go through this problem.
I have a task wherein, i need to implement the following steps.
1) Open a existing spreadsheet file( consisting of p and s columns)
2) Remove peaks of s column by selecting a certain value and then removing the corresponding p column values.
3) I then need to take the moving average of both the p and s columns with interval 10. By this i mean, if i have the following points say
x avg(x) with interval 10
1 N/A
2 N/A
3 N/A
4 N/A
5 N/A
6 N/A
7 N/A
8 N/A
9 N/A
10 (average of 1 to 10) = 5.5
11 (average of 2 to 11) = 6.5
12 (average of 3 to 12) = 7.5
I have been able to complete the first two steps
I have seen examples of 1d array moving averagin. Since the array is a 2d one, i am slightly confused on how to take the moving average of both the columns at once.
can anyone suggest me a way forward.
Attaching the excel and the VI.
Thanking you.
Pa1
04-04-2017 12:57 AM
If you need to take the Moving average of P and S Columns Separately, Index this columns into two 1D array and do a running average by taking the array subset where the offset should start from 0 to N and the Length remains same Assume 10
Hope this will help you!
04-04-2017 12:59 AM
Thanks PalaniveIT for your reply.. can you show me a screenshot of how to index the columns into 2 different arrays..
04-04-2017 01:40 AM
I gave a try..is it the right way to do array indexing?
04-04-2017 01:44 AM
If you are acquiring data continuously instead of Loop can be eliminated the indexing can be Maintained in Acquiring Loop or using shift register
04-04-2017 02:19 AM
