04-13-2006 02:07 AM
04-13-2006 01:55 PM
Unfortunately this can't be done with the event structure (maybe in 8?), but you can do it with the input VIs which can be found in the advanced palette. Then, you can run this in a seperate loop and fire dynamic events so the event structure will react.
I think this is something which should be in the event structure and to let NI know about it you can try clicking the Contact NI link at the top of the page.
04-13-2006 01:56 PM - edited 04-13-2006 01:56 PM
Message Edited by Jonnie 5 on 04-13-2006 02:57 PM
04-13-2006 02:01 PM
As far as I know, the Event Structure does not have any events for mouse scroll wheel detection. However, in LabVIEW 8.0, native scroll wheel support was added to scrollable front panel objects (Tree Control, Listbox, Table, and Multicolumn Listbox). So if that's the functionality you were hoping to accomplish with events, it's already done for you in LabVIEW 8.0.
-D
04-13-2006 02:24 PM
How about arrays?
In any case, I could see cases of users wanting this for other things, so I would add event structure support for mouse wheel scrolling to the wish list.
BTW, speaking of event structures, are there any plans to add the ability to dilute repeating events?
Key repeat or Mouse Move events, for instance, fire a ton of times too much. In the case of mouse move this is extremely annoying because adding code to do the dilution yourself does not handle cases in which the mouse move stops. It would be nice if such events could be configured to fire only if the mouse has moved X pixels or every X milliseconds or if X amount of milliseconds passed since the last time the mouse moved and it hasn't moved the minimum amount.
How about that?
04-13-2006 02:33 PM
Sounds like somebody needs to make a visit to the Product Suggestion Center webpage... 😉
-D
04-13-2006 02:38 PM
It's always better to hear "Yes! Everything you want will be available in 8.1 which will come out exactly 5 months from now" directly from R&D instead of going that way.
@Darren wrote:
Sounds like somebody needs to make a visit to the Product Suggestion Center webpage... ;)
04-13-2006 05:26 PM
04-13-2006 07:52 PM
Here is a thread that might help.
http://forums.ni.com/ni/board/message?board.id=170&message.id=174449#M174449
04-14-2006 01:54 AM
