09-13-2006 04:47 AM
09-13-2006 04:58 AM
09-13-2006 07:01 AM
09-13-2006 07:07 AM
Was there any errors?
What data did you send? Give me an example of what you are trying to send to the device
What data should you receive? Give me an example of what you expect to see back.
You could also post what you have done so using the Attachment button below the Message body when you post.
Basically we will need as much info to give us a clue what could be going wrong.
cheers
David
09-13-2006 10:06 AM
David
Errors that occured were timeouts!
The data that I am sending to the instrument is 'h/00' , this command tells the instrument to start. 'i/00' stops the instrument from taking a reading and when it does this, it automatically does a screen dump of from the instrument on the RS232 data cable.
What I am trying to do is have my program ready to accept the data that is sent out from the instrument and record it.
The data that comes back is just ASCII, such as 'Time : 20 seconds'
I would like to attach sample code of what I am trying to do but there are no facilities where I work to upload anything onto the web.
I can get the same result of a screen dump if i push the stop button on the front of the instrument, I have just been trying to create a program that will capture the data when it see's it, The program normally comes back saying that the VISA read vi has timed out.
In the ideal situation I would like a Hyperterminal window displaying the data that is being sent / received on Com 1 and a labview program with buttons to control the instrument.
09-13-2006 10:21 AM
09-13-2006 12:55 PM
09-13-2006 03:40 PM
09-14-2006 04:39 AM
09-14-2006 05:49 AM - edited 09-14-2006 05:49 AM
There is a property node that you can use to move the scroll position within the string indicator
This will ensure that scroll position is always beyond the length of your string.
Let us know if that helps you
David
Message Edited by David Crawford on 09-14-2006 11:50 AM
