Hello mnk,
In order to change the max value on your graph, you can simply double-click on the last number (0.1 ms in your case) and type in what you want. Also, if you're trying to extend the view past the last data point, you will have to make sure that the "AutoScale X" option is NOT selected. You can check this by right-clicking on the graph, then going to
X Scale >> AutoScale X.
If you're still getting the error, please go to the webpage I mentioned in my previous post and follow the instructions listed there.
