Modifying the Continuous Measurement and Logging Sample Project
I'm learning how to use the QMH style by modifying the Continuous Measurement and Logging project to suit my needs. However, I am running into a seemingly simple issue. Instead of the Waveform that is queued I want to use a 2D string instead but I receive the following, not very useful, error message. Is there a type-def that I need to modify somewhere to be the 2D string?
(3,585 Views)
Hi abeaver,
It looks like the data type expected in teh Logging Message Loop VI is a 1D array of a Waveform type. The 2-D array of string type will cause a broken wire when it is connected to the input. It may be possible to modify the example to work, but this example was made for waveform data.
Andy M.
(3,546 Views)
Thanks! I just went ahead and used the standard Queded Message Handler template.
(3,494 Views)
