01-20-2016 10:51 AM
could you please post the code you are using currently? I would like to take a look into it.
Best,
Melanie
01-27-2016 02:46 AM
Hi
The document doesn`t help unfortunately.
I am attaching the code which I am using but it hasn't changed a lot since my first post.
Lukas
02-01-2016 02:57 AM
Hi stiefel,
try to initialize the boolean value you are passing to the function MB Serial Master Query Read.
Maybe this might generate the timeout error.
Kind regards,
Pep
02-01-2016 08:21 AM - edited 02-01-2016 08:22 AM
Try reading Holding registers instead of input registers.. Also use a bundle by name for your cluster.
02-03-2016 04:54 AM
Hi
Thank you for your help. I rebuilt the program as Dave has mentioned and still get the
error -1073807298 ocurred at VISA Read in MB Serial Receive.vi:3-> MB Serial Master Query.vi:2->PID-Read.vi
Possible reasons:
Visa: (Hex 0xBFFF003E) Coud not perform operation because of I/O error.
I get this same error using the set_temperature.vi and it still sets the temperature correctly. The controller also shows a little light indicating communication over the interface when running any of the programms.
So the same error as before which I have mentionend in Message 9. Any suggestions how to resolve that problem?
Lukas
02-03-2016 06:09 AM
Have you tried increasing the timeout value? What is it set at? Also is your address the same for unit ID in the controller? You can by sending a broadcast "Unit 0" and all will except the values for setpoints (Writes) but if you request data from a controller and it does not have the same ID it will not respond. The slave Address must be the same as what is set in your controller.
02-03-2016 07:27 AM - edited 02-03-2016 07:28 AM
The timeout value is set to 10000 and I have tried increasing it but it doesn't make a difference. Anyway I am not getting a timeout error right now.
The slave address of the controller is set to 2. When I am using the programm "Simply Modbus Master" communication works fine.
Thanks for your efforts.
02-03-2016 07:53 AM
If you can use a different controller Automation direct has a good selection. I use Automation Direct Solo temperature controllers with the same NI modbus library and it works very well. Automation direct makes a modbus serial to modbus Ethernet gateway. It works very well. This eliminates a lot of the serial port problems with converters and also allows for setting up polling of slaves in the gateway.
