05-18-2016 04:25 AM
Hello all,
I am facing an issue of huge memory building up in my application while I try to pass the reference of a mixed signal graph I build. I am saving the graph as jpg or png image in a SubVI using the reference received. I could not see any potential reference leaks even with DETT .I had already tried the following updates to reduce the memory build but I couldn't see any potential reduction in the amount of memory built.
I have reproduced the issue by creating a prototype from the piece of code which was building memory. I could not still figure out the exact reason for the issue. It would be great if I could get solution or suggestions on how to proceed on this. The Main VI will have the default value in the mixed signal graph which is similar to the actual data used in our application.
The prototyped code is in LabVIEW 2012.
