Mitsubishi FX thru LabVIEW
What you can do is. There is Communication manual for fx1n, fx1s Fx2n PLC.
There you will get communication protocole.
that String you can send though VISA serial VI.
You will be able to get D words from the PLC.
CLAD
Labiew programmer
Message 11 of 26
(5,199 Views)
Here is the glimpse of my LV program and the command protocol for PLC write:
writing to single point of Mitsu PLC.
1-1 connection
I receive nothing in the read buffer. im still figuring out.
19585iA4E80F7C0703C3FB
Ivel R. | CLAD
Message 12 of 26
(5,186 Views)
Did you set PLC commiunication parameter. and then download program along with parameter.
for more details refer the xl sheet attached.
Refer Attached
CLAD
Labiew programmer
Message 13 of 26
(5,178 Views)
yes, i set the parameters of mitsubishi FX. is as follows:
stopbit = 1
X'misson speed = 9600
databit = 7
parity = even
port = RS232C
dedicated protocol
form1 (w/o termination)
station # = 00 (coz 1-1 conection only)
Ivel R. | CLAD
Message 14 of 26
(5,176 Views)
hi to all,
I've been working with this for almost a month (getting really frustrated) and still having unclear path to the right solution.
anyone have LV code for Mitsubishi FX PLC?
Ivel R. | CLAD
Message 15 of 26
(5,140 Views)
Any reason you are using DSR/DTR for flow control where you configure the serial port?  The diagram you posted in the .xls file does not show any handshaking wires.
Also, use the Wait function rather than the wait until msec function between your VISA write and your VISA read.  The 1000 msec, wait until next means it will wait up to 1000 msec, but it could be nearly 0 msec if the code before it happens to end right before the 1000 msec interval of the computer occurrs.
Message 16 of 26
(5,132 Views)
Hi ravens fan,
thanks for dropping by (coz i remember, you already helped me solve several LV problems before). Actually, I have to many things w/c i don't understand well about the settings. here are the following:
1. Mitsubishi FX PLC hardware is RS-422 port. But we used converter RS-232C to used to connect to computer. So one issue is i really dont know wether i will used RS-232 or RS-422 in PLC set-up.
2. about the DTR/DSR, i'm not sure about this, I just check the PCB inside my rs422-rs232C converter and saw the ff: Tx, Rx, Gnd, DTR, DSR. so i assumed the handshaking is DTR/DSR. but i'm confused coz i did'nt saw any handshake selection in PLC set up.
3. the FX PLC model only recommend to used these settings: 9600 transmission rate. so i have no idea on what do i really need to used about the data bit, stop bit, parity bit. maybe because the mitsubishi FX family has too many models, the manual does'nt afford to specify its communication settings.
now i am making the loop-back test from mitsubishi command and still got very unusual data. i will try to change the waiting function.
regards,
ivel
Ivel R. | CLAD
Message 17 of 26
(5,128 Views)
I still get the same result as shown below. when i'm using LV thru OPC server, i can control and monitor the PLC bits. but no in direct serial connection. i'm wondering if the MX component of mitsubishi is really needed for this situation.
21710i9C0EDB5926C7A39A
this command is for PLC-PC loopback test as shown below.
21712i6B31050F1FC38766
Ivel R. | CLAD
Message 18 of 26
(5,115 Views)
attached the vi.
Ivel R. | CLAD
Message 19 of 26
(5,111 Views)
Message 20 of 26
(5,102 Views)
