01-19-2010 01:02 AM
Hello 2 all !
I'm using LabView 8.5.1 on Windows XP SP2 and i'm trying to buid a executable based on a working vi.
But the build fails because, and i quote:
"Error copying files.
Source: D:\Program Files\National Instruments\LabVIEW 8.5\AppLibs\lvapp.lib
Destination: C:\Documents and Settings\Administrator\Local Settings\Temp\lvapp.lib.tmp"
" Error 7 occurred at AB_Engine_Get_AppShell.vi -> AB_EXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
"Possible reason(s):
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer. "
How can i solve this ?
Thank you 4 your time.
01-19-2010 01:08 AM
I've searched tryed the following things :
1. Repair LabView - no luck.
2.Search my computer for lvapp.lib - no file found.
I've searche the forums, and came across http://zone.ni.com/devzone/cda/tut/p/id/6449#65891_by_Category.
This error should have been corrected in LAbView 8.5.1.
What else can i try ?
01-19-2010 01:08 AM
01-19-2010 01:10 AM
01-19-2010 01:11 AM
01-19-2010 01:17 AM
01-19-2010 01:18 AM
01-19-2010 01:21 AM
01-19-2010 01:22 AM
01-19-2010 01:25 AM
